Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double u joint set up question
Old 01-08-2007, 06:06 PM
badA31 badA31 is offline
With a shaft that long there may be some slight deflection from normal driving vibration, but not enough to break anything. If you want to add a carrier bearing in just to make yourself feel better, then I suggest mounting as close to the center as possible. From your picture it looks like that's the best location to build a bracket from anyway.
