I just re-read your post and I may have mis-understood you. I thought you meant TWO u-joints when you said "double". If you meant a double on one end and a single on the other then you will most definately need a carrier bearing as close to the "double" u-joint as you can get.
Go to Borgeson Universal's website and download their catalog. It has set-up diagrams.
