Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double u joint set up question
Old 01-09-2007, 01:12 AM
artillerystevens's Avatar
artillerystevens artillerystevens is offline
1950 Chevy Pickup custom!
Last journal entry: Dash
Clarification
Sorry about the wording... The shaft has a u joint at each end. I know this will work if there is no play in the mounts at each end.. at the steering box, and at the steering column. The problem I am worried about is that the mount on the steering box itself. It can flex up to 15 degrees or so.. I think I am just going to make that "joint" solid leaving the 2 u joints being the only points that can pivot. After spending some time at the shop playing with it, I believe that will work well.
