Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double u joint set up question
Old 01-09-2007, 05:31 AM
Ed ke6bnl Ed ke6bnl is offline
Originally Posted by artillerystevens
Sorry about the wording... The shaft has a u joint at each end. I know this will work if there is no play in the mounts at each end.. at the steering box, and at the steering column. The problem I am worried about is that the mount on the steering box itself. It can flex up to 15 degrees or so.. I think I am just going to make that "joint" solid leaving the 2 u joints being the only points that can pivot. After spending some time at the shop playing with it, I believe that will work well.
my understanding and experience is that you need to REMOVE the rag joint and make a solid u joint connection at the box. I then think you will be fine. There should be a spline joint under there after removing the rag joint. The bolt needs to completely removed to remove the joint good luck ED ke6bnl
