Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double u joint set up question
Old 01-09-2007, 01:32 PM
badA31 badA31 is offline
Ed k is right on about that u-joint. If you look at the Borgeson website they recommend not using the rag joint on anything but a straight line application.
If you just go to one U-joint only, on each end of that shaft, then you won't need any more support in between.
