Double Vs Single Flaring tool?
I was looking at Oreilly's and Autozone earlier today for flaring tools. I need to do some work on fuel lines for my caddy. Basically I need to clean up on or two ends and replace the nuts. I have nuts from a new fuel line. But the factory line is bent much better, so I would rather use it.
So what is the advantage of a double flaring tool over a single flaring tool? It is not something I am likely to need all that often. So if the cheaper one works almost as well I would probably go that route. |
flaring tools
you must double flare 45 degree steel tubing.you can single flare 37 degree tubing as used on an fittings.
Double flares are for brake lines....Fuel lines dont need double flares.
Ontario Rodders |
Edit- That's not to say there aren't other ways to do it- the factory now uses bubble 'flares', etc. |
Early days
all brake lines were double flared, they were stronger and did not leak after a week of using the brakes double flare gives the nut more beef to seat on. A single flare gets burred up with the nut tightening and the more you loosen and tighten them the more likely to leak from wear. been there and done that, I had my share of leaks until i learned the double flare trick
The only time you do a single flare is when you're using stainless steel lines and then the flare is 37 degrees. Steel brake lines are always double flared at 45 degrees and if your fuel lines use an inverted flare fitting you need to double flare those as well.
Centerline HotRodsAndHemis.com "If guns kill people, then...... pencils miss spell words, cars make people drive drunk, and spoons made Rosie O'Donnell fat!" - Anonymous |
flaring tools
most times when you single flare steel tubing at 45 deg it splits.
| Recent Garage - Tools posts with photos |
| inexpensive 37 degree flaring tool | 1930u | Garage - Tools | 5 | 06-14-2011 05:45 AM |
| Bubble flaring tool? | staleg | Suspension - Brakes - Steering | 4 | 05-04-2010 03:33 AM |
| Flaring tool | 57halfton | Garage - Tools | 4 | 12-21-2009 08:55 AM |
| Who makes good fuel line flaring tool? | rajsid | Engine | 13 | 09-01-2009 10:49 AM |
| 45 degree flaring tool | ratrod47 | Garage - Tools | 7 | 05-18-2009 09:50 PM |
