-   -   Doug Nash 5 speed (http://www.hotrodders.com/forum/doug-nash-5-speed-154941.html)
redride 03-13-2009 06:32 PM
Doug Nash 5 speed
I have a Doug Nash 5 speed in my nova and am pulling out the 396 and putting in a 505 (454 stroked). Does anyone know what pilot bushing I need to use????
dlc1979 03-13-2009 07:44 PM
I believe that all Chevy pilot bearings/bushings are the same size, whether SB or BB.
Jegs lists them: OD = 1.093, ID = .591, Length = .750, P/N 60105.
redride 03-13-2009 07:49 PM
I went to the parts store earlier and they said that they showed 2 different ones for a 454 so I have no clue.
jimfulco 03-15-2009 10:13 PM
Ask them if one's a bushing and one's a roller bearing.
dlc1979 03-16-2009 08:47 PM
If you've got a micrometer, mic the ones at the part store. One of them should be close to the Jegs dimensions I gave you.
Haven't put a roller bearing in a crank, but it sure helps a lot when installing the bronze one if you put it in the freezer overnight... shrinks it enough that it goes in a lot easier.
cobalt327 03-16-2009 08:50 PM
If the price for one is like 4X what the other one is, one's a roller, other's a bushing.
redride 03-16-2009 08:50 PM
Thanks for the info. I had been told that a big block and small block were not the same. I have one on order now.
57halfton 03-18-2009 06:50 PM
Wow I would have figured they were all the same . One thing that comes to mind is your flywheel , 396 is internally balanced a 454 is externally balanced , make sure you use the proper flywheel, it's a easy mistake to make , alot of people have done it and wiped out all the bearings in a very short time.
Gene
redride 03-21-2009 10:23 PM
Thanks for the info Gene, I did get a new flywheel that is ex. ballanced.
