Doug Nash 5 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2009, 05:32 PM
redride's Avatar
1969 Nova SS502
Doug Nash 5 speed
I have a Doug Nash 5 speed in my nova and am pulling out the 396 and putting in a 505 (454 stroked). Does anyone know what pilot bushing I need to use????
Old 03-13-2009, 06:44 PM
I believe that all Chevy pilot bearings/bushings are the same size, whether SB or BB.
Jegs lists them: OD = 1.093, ID = .591, Length = .750, P/N 60105.
Old 03-13-2009, 06:49 PM
redride's Avatar
1969 Nova SS502
I went to the parts store earlier and they said that they showed 2 different ones for a 454 so I have no clue.
Old 03-15-2009, 09:13 PM
Ask them if one's a bushing and one's a roller bearing.
Old 03-16-2009, 07:47 PM
If you've got a micrometer, mic the ones at the part store. One of them should be close to the Jegs dimensions I gave you.
Haven't put a roller bearing in a crank, but it sure helps a lot when installing the bronze one if you put it in the freezer overnight... shrinks it enough that it goes in a lot easier.
Old 03-16-2009, 07:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the price for one is like 4X what the other one is, one's a roller, other's a bushing.
redride's Avatar
1969 Nova SS502
Thanks for the info. I had been told that a big block and small block were not the same. I have one on order now.
Old 03-18-2009, 05:50 PM
57halfton's Avatar
Wow I would have figured they were all the same . One thing that comes to mind is your flywheel , 396 is internally balanced a 454 is externally balanced , make sure you use the proper flywheel, it's a easy mistake to make , alot of people have done it and wiped out all the bearings in a very short time.
Gene
Old 03-21-2009, 09:23 PM
redride's Avatar
1969 Nova SS502
Thanks for the info Gene, I did get a new flywheel that is ex. ballanced.
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
what does a speed censor do? notmrgoodwrench Engine 1 06-15-2005 05:27 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 02:40 PM
difference in 2 speed to 3 speed auto? HemmiGremmie Hotrodders' Lounge 2 12-17-2002 05:31 AM
