doug nash tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2009, 07:50 PM
doug nash tranny
I'm new to this site so please forgive me if I don't do this just right---- Here goes----- I am building a 68 camaro and I already have a 454 bored .060 over , eagle forged rotating assembly , a .540/.540 comp cam and hydraulic lifters , I have a Doug Nash 5 speed with a long vertigate shifter . I have a lakewood bell housing and I've already purchased a ram billet flywheel , ram clutch, ram pressure plate . The bearing surface for the throwout bearing on the tranny is about 1.37 (od) . My question is what throwout bearing am I going to need to use ? I've talked to the tech line at Summitt and they have no clue , I called Richmond and they were absolutely no help , and I just want to get this right, so if anybody can help me , I would really appreciate it-------thanks//Tony
Old 02-03-2009, 10:48 PM
I'd get ahold of the tech people at Ram, tell them what you have, and let them tell you what you need.
Old 02-04-2009, 10:38 PM
I've run many of the DN Competition 5 sp, and Torsion Tube clutchless trannies, and you really only have two choices,either the long or short throwout brg. Depending on the pressure plate style, Borg & Beck, or Long style. Look on your pressure plate and it should have the info stamped on it as to what type it is....
Dark brown tranny fluid slyhog22056 Transmission - Rearend 6 10-12-2008 05:39 PM
89 Astro van tranny problems, rebuild help questions searay Transmission - Rearend 14 05-31-2008 04:26 PM
Tranny to cross member alignment issue Blue67Camaro Transmission - Rearend 5 01-14-2008 01:24 PM
!993 T-Bird Tranny Re-build Mike in Canada Transmission - Rearend 8 06-29-2007 07:09 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
