down shifting 700r - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 10:59 AM
down shifting 700r
ok, im running along bout 70mph , converter locked in.
when i floor it , it just accelerates (converter stays locked in), but dont kick down a gear. is this normal ?
ps i got a manual switch to turn the converter off and on for town driving.
thanks , roger
Old 08-21-2011, 11:36 AM
sqzbox's Avatar
My pipes are my music
thanks , roger
So..... are you un-locking the converter when you floor it? If not, it's not going to downshift when locked up. In order to down shift, your going to either have to manualy pull it down or un-lock the converter.
Old 08-21-2011, 11:46 AM
sqzbox , yep thats what i did (unlocked it manually ) and it down shifted.
just wanted to make sure the tranny was working properly .
does it hurt anything to pull it down while locked up and then shift it back when pass completed ( all the time leaving it locked up) ?
thankyou very much, roger
Old 08-21-2011, 12:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Shifting the transmission while the converter clutch is locked up is not recommended. The shifts will harsh.
there is a spring loaded hub on the converter clutch inside, that hub does not hold up well under shifting if clutch is locked up
Old 08-21-2011, 01:37 PM
ok crosley, i wont dodat.
thanks, roger
Old 08-21-2011, 02:22 PM
sqzbox's Avatar
Yeah, I tried that with my 88 F-bird. Had a manual switch I put in when I had a problem with the auto lock-up. Shifting with the converter locked up didn't feel right so I didn't do that either.
700R Shifting Hard and Late Gokussj5okazu Transmission - Rearend 4 04-02-2010 07:28 PM
700r shifting problems hot 67 Transmission - Rearend 2 11-13-2008 04:17 PM
700r shifting problems osu1fan Transmission - Rearend 2 07-02-2008 08:20 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
700r shifting problems Randy Transmission - Rearend 2 10-06-2003 08:54 AM
