Drag 4 link compared to street - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2011, 11:58 AM
the dan's Avatar
83 chevy c10 long bed
i own a small fab shop and have done a few 4 link set ups for street trucks, Setting it up around the center of gravity roll center.. etc.. i have read the manual over and over. What my question is how different should i set up one on a drag truck compared to a street truck?. i know most drag cars have a bunch of different axle mounting locations for the lower and upper bars, any insite on why and/or what it would do at the high extream and or low extream? thank you
-the dan
Old 02-22-2011, 12:09 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Maybe this will be some help: http://www.racetec.cc/shope/
Billy is very knowledgeable and a regular here.
Old 02-23-2011, 05:36 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
I'll save you a little time searching at my site. For a street car (or truck), you should probably back off a bit on antisquat to avoid wheel hop during braking. You might use 100% for the strip, but only 50% for the street.
Old 02-23-2011, 09:20 PM
bentwings's Avatar
bentwings
I've been over Billy's site one end to the other many times. I pick up something I missed everytime I read it. great info.
I have a true 4 link on my Willys Pro street that I built myself. The rear end is very narrow with big tires. At first with the locker in it would kick the rear end over to the right and leave a pair of big "C" on the pavement. I added a 1 1/4 in anti roll bar that is only about 18" long so it is very stiff. I was actually worried that it was too stiff for the street so I made up a pair of spring loaded links. These had heavy die springs. They worked ok but only flattened the "C" so it really needed some pre load. I then made a pair of solid links with left and right rod ends. I tried no preload and it was better than the spring loaded links but still the car didn't launch as straight as I wanted. I added 2 full turns preload and that did the trick. It launches nice and straight. I disconnected the bar and tried it again just to verify the result and the car did the big "C" again so I connected everything back up.
Now, on the street right turns like freeway cloverleafs are pretty good, it really digs in. But on left turns it noses over a little, not bad but I can notice it easily. I backed off the preload 1 turn and that seemed to help and is a good compromise.
As for anti squat, according to the calculations I get about 50% over neutral. This seems to work very nice. I don't have any braking problems even in the rain. I tried a hard stop in the rain and it still stops very well even with the big Hoosiers. You just don't want to go into boost in the rain however. haha
Pitman Arm and drag link location hotwheels1 Suspension - Brakes - Steering 2 01-02-2011 03:55 PM
67 El Camino - Drag Link starnest Suspension - Brakes - Steering 7 06-24-2010 12:54 PM
To 4-Link or not. Best for Drag Racing S10 Racer Suspension - Brakes - Steering 7 01-21-2010 07:57 AM
Help on extending drag link/connecting rod bartamos Suspension - Brakes - Steering 4 03-28-2006 03:35 PM
Drag Link Question (Center Tie Rod) Houman SS '70 Suspension - Brakes - Steering 2 03-26-2005 08:56 PM
