Drag Car windows
I'm looking for some ideas on how to mount lexan windows that can be quickly removed. The side windows will be attached to a fiberglass door. Can lexan be manipulated with heat? Is there a glue that will reliably attach lexan to itself?
Might want to try Plexi-glass instead. Lexan is very hard and cracks easy. Plexi-glass is more forgiving and costs a whole lot less than Lexan. :D
The above post is backwards, Lexan is haetable and can be formed in a press brake and cut on a sheare.On the other hand plexi-glass is lower cost but brittle and will chip, crack and is not formable.
I have worked with this stuff for years. For adhearing Lexan I use clear silicone. I have made machine guards and even bullet proof windows with Lexan.For auto windows you can get it with a harder finish outer coating but still requires gentle cleaning. |
Lexan costs quite a bit more than Plexiglass, at least it does around here. |
I have built aquariums from sheets of lexan using methylene chloride. It is a solvent rather than a glue. It bonds the two pieces together into a single piece, rather than just sticking them together. It takes a little skill to use, but it is the way to go.
You can usually buy it at the place where you buy your lexan from.
Wow....it seems the greenies have really taken over since I built my last aquarium. I guess you can't just buy it at the local place any more. It is still available online.
http://www.enasco.com/product/KM01075M The best way I found to apply it with is with a syringe or needle-nose applicator bottle. It is fluid...no viscosity at all. |
| All times are GMT -6. The time now is 10:14 AM. |
