drag launch front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2006, 08:07 PM
cardaddyo's Avatar
always the hard way...
could some one help me find "trick " front springs for an s-10 blazer.moroso seems to have an extensive line of these springs i just dont know which ones will/wont work.also these springs are rated at 217-270 lbs,what would be a good for my 2 wd 89 s-10 blazer,v-8 swap(283,headers,power steering,stock lower a-arms,tubular uppers) just an idea of what is on the front end.if need more info just ask thanks i have searched the s-10 forums,v8-s-10,blazin low,etc. but no help.i figured a few hotrodders could swing some info like this thanks again
Old 02-27-2006, 06:31 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Page 7 of http://home.earthlink.net/~whshope describes the use of biased front spring rates to equalize rear tire loading during launch.
(Moderator: Why is my old picture still being displayed?)
Old 02-27-2006, 06:22 PM
S10's use the same suspension and steering (except for the center link which is shorter on the S10) as G-bodies. Look for springs listed for a 78-87 Monte Carlo.
Old 02-27-2006, 10:51 PM
cardaddyo's Avatar
what sort of weight should i look for if i go w/ the montes? i believe my veh. weight is around 3400-3600 lbs,so how could i cross ref. this to my project?
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
Front coil springs too long. hrussel Suspension - Brakes - Steering 3 07-23-2004 07:36 PM
front coil springs 92 power ranger Hotrodders' Lounge 0 07-12-2003 07:55 PM
Installing New Front Springs horvath Suspension - Brakes - Steering 7 06-07-2003 08:04 AM
Eibach Drag Launch Springs? stonedchihuahua Suspension - Brakes - Steering 0 11-18-2002 12:28 AM
