Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - drag link question....
Old 08-10-2012, 05:40 AM
thintin thintin is offline
i've seen drag links in cowl steering setups mounted above and underneath the steering the case of a heim joint end with the retaining bolt either nut end up or the tierod end application ....the rod end thru from the top (nut under the steering arm)....or under the steering arm(nut on top of the arm) there a hard and fast rule concerning which way the drag link is mounted (assuming correct geometry) or is simply a case of best clearence and appearance? hope this question makes sense....thanks for the input
