Drag racing 700r4 with lockup converter locked? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 12:28 PM
Fang16's Avatar
Last journal entry: Project change
Pros and cons of drag racing a 700R4 with lockup converter locked? I know there are different ways to lock the converter, electrical and the check ball trick and that it won't lock in 1st, just wondered what the ramifications are when dragging with it locked. With my gearing it only see's 3rd for a short time in the 1/4.
Old 03-28-2013, 05:41 AM
locking the converter usually gives u more mile an hour at the end of the quarter.most guys doing this are using a multi-disc converter and locking it up after 3rd gear.if your only in 3rd for a short time and using a stock type converter, you may see no gain and eventually burn up the clutch.
The Following 2 Users Say Thank You to trannyguy For This Useful Post:
boatbob2 (03-29-2013), Fang16 (03-28-2013)
700R4 converter lockup/questions sbc307 Transmission - Rearend 16 12-02-2011 06:35 AM
700R4 Converter ALWAYS Locked Up 1972RedNeck Transmission - Rearend 11 07-15-2011 04:35 PM
700r4 lockup converter questions 71/454 Transmission - Rearend 2 01-17-2010 08:36 PM
Should ignition timing be locked out for drag racing? chevyv8_power Engine 2 05-04-2008 12:33 PM
700R4 lockup converter help needed Augusto Transmission - Rearend 2 01-21-2008 02:24 PM
