Drag racing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2005, 01:41 PM
Malibu406's Avatar
New Member
Can anyone explain why you have a faster MPH if you spin your tires off the line when racing. A knowledgeable racer explained to me why a few years back and I've been trying to explain to a few people, but I can't remember exactly why it happens. A few of my friends have got excited over their MPH on a run and they think its going to be more when they get their car to hook and launch good, I told them the MPH will go down a tad but they don't believe me.
Thanks for any help
Old 07-12-2005, 04:09 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
well dont quote me on this but i know that when a top fueler get moving the rear tires flex outward, in essence creating a bigger tire diameter creating more surface .
when the tire stands up its like it creates a overdrive adding more to the mix
but i think too much tire spin is going to effect your time
hope this helps
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-12-2005, 04:22 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
When you spin your tires off the line, you move up in the RPM band because it is just spinning and not moving forewars. Rev's make MPH not ET when you aren't moving foreward. I get lousy RT's when I slip on the line.
Old 07-12-2005, 04:48 PM
steve t's Avatar
ex biker, now hotrodder
spin and lose the race, they heat up tires before they stage.
Old 07-12-2005, 05:49 PM
1982 SS's Avatar
Flamethrower
Luckily, when I slip the other guy slips more (usually) I don't launch very hard compared to some others.
Old 07-12-2005, 07:11 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
The reason is because the power exceeds the tires ability to grip the track. When this happens the tires spins. Well when the tire begins to spin its maximum grip lowers and less forward acceleration occurs resulting in a slower ET.{ I can see everybody rolling their eyes and thinking " No ******* Sherlock"}.
But what also happens is that energy is still being put into the tires as rotational inertia. At some point the vehicle speed will near the tire speed and the tires will grab. When they do grap it lunges the car forward as the inertia they have built is released as forward momentum.
Basically the tires act as a bettery to store the energy until it can be applied. Since the car has been under power for a longer period of time more Hp has been used and MPH is a function of the amount of Hp.
Drag Link Question (Center Tie Rod) Houman SS '70 Suspension - Brakes - Steering 2 03-26-2005 08:56 PM
Drag Racing the '78 78SilverShark Hotrodders' Lounge 8 10-21-2003 05:22 PM
Racing Gas Question Jag Daddy Engine 3 10-20-2003 03:01 PM
drag racing motor vega dog Engine 7 10-16-2002 06:22 AM
