Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drag Radials or Drag Shocks?
Old 04-10-2012, 06:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Brian Morency
Just wondering which should come first for a better track time. Would someone benefit from drag radials over drag shocks, vice versa? I have an 86 Camaro stock shocks and Bf goodrich t/a 60 tires. They are about 10"wide tread contact but hard rubber. Would a Bf goodrich drag radial help more then drag shocks? Same size tire of course.
Drag radials w/o a doubt will be the biggest traction improvement you an make short of a drag slick- which you cannot use on the street.
The caution about your diff is a valid point, too. If you're making any power to speak of, and it hooks up on a hard launch (like at the track on a prepped surface) the diff can easily let go. What saves these spindly rear ends is the lack of traction.
