Drag Radials or Drag Shocks?
Just wondering which should come first for a better track time. Would someone benefit from drag radials over drag shocks, vice versa? I have an 86 Camaro stock shocks and Bf goodrich t/a 60 tires. They are about 10"wide tread contact but hard rubber. Would a Bf goodrich drag radial help more then drag shocks? Same size tire of course.
I just seen to also weld on a pair of lower control arm relocation brackets. Which will help reduce wheel hop. That this is a must adjustment for these cars. Also that the quickest 60' I will be able to run with stock rear end before it breaks is about a 1.7
You will definitely need a different axle once you begin to hook it up. The 7.5/7.625 is weak. The torque arm acts as a long ladder bar and puts considerable stress on the housing. A 9'' ford would be a smart addition. The 8.8'' Ford axle isn't bad but has c clips like the 12 bolt.
I found a site for direct bolt on 9" from hawks. Its like 3 grand for the one I want. Guess its time to start saving. I'm not even going to bother welding up some lcarb's seems like a waste of time. I'll box the lca's when I weld up the sub frame connectors.
Drag radials.
Cole
The caution about your diff is a valid point, too. If you're making any power to speak of, and it hooks up on a hard launch (like at the track on a prepped surface) the diff can easily let go. What saves these spindly rear ends is the lack of traction. |
+1 on the drag radials and the rearend.
I broke mine 3 times in two years and was only cutting 1.88-1.94 60' times. I've seen people get away with much harder launches than that on 7.5/7.625 rears but it didn't work out so good for me. |
| Goodyear Drag Radials | NovaJoe1973 | General Rodding Tech | 1 | 12-07-2011 11:01 PM |
| Drag Radials | OLNOLAN | General Rodding Tech | 3 | 07-05-2011 10:07 PM |
| Drag Radials | mr_lwhite | Engine | 1 | 05-28-2010 12:58 PM |
| Drag radials and 4 speed? | turchiac | Suspension - Brakes - Steering | 2 | 05-17-2010 07:50 PM |
| Drag Radials or Slicks? | 6567GTO | General Rodding Tech | 5 | 06-06-2003 04:25 PM |
