Dragging Brakes
I recently changed a set of front rotors and disc on my 1957 Chev.. Bel Air because they had built up so much that they actually caught fire and stop the vehicle from rolling. I originally thought they pistons wear gummed up from sitting so long causing them to drag and the resulting heat build up. So... not the case I changed them for a new set of CCP 11in. brakes and rotors and Iam experiencing the same problem. Can any one tell me what I am doing wrong
Thanks |
I would look at the brake hoses
Artificial Intelligence is no match for Natural Stupidity Chet |
Its an easy check when your brakes are tight and the pedal is all the way up crack a bleeder if there is a lot of pressure this might be your problem. A master cylinder with a sticking internal piston can cause this too! These are only a couple of things that can cause your problem! There are more!! Jester |
Did you find the problem ?
Brake trouble
Painted jester, thanks for that info.
Many years ago I had exactly the same problem on a T-bucket, Buick front discs and master cylinder. It would start dragging even if we were just towing the car. For the life of me I couldn't figure out what it was at the time (20 years ago). At the race track I disabled the front brakes and ran just using the emergency brake...couldn't get the pedal to stay up after I put the front brakes out of action. I am almost 100% certain it was because I didn't put the prop valve in right. Thankfully no one got hurt. |
Chris
Thanks again. |
It a very common mistake I must see at least 2 a year !!
Your thank you makes my day Thank you for that: Chris |
| My dark, knuckle dragging, side. | deckofficer | Hotrodders' Lounge | 6 | 08-12-2011 08:07 PM |
| disc brake caliper dragging | slammed 57 | Suspension - Brakes - Steering | 3 | 01-22-2010 11:56 PM |
| 80 camaro drum brake dragging | toddiyaayas | Suspension - Brakes - Steering | 11 | 05-19-2008 01:07 AM |
| Dragging brakes? | FrankR | Suspension - Brakes - Steering | 2 | 12-06-2005 09:20 PM |
| 76 Monte whose "A_ _ is dragging | bigjoedo | Suspension - Brakes - Steering | 8 | 05-19-2003 08:21 PM |
