Regardless, I'd bet your next two paychecks that if they put a carburetor only rule in, within 5 or 6 years the top guys would be going 350mph on carbs!
One of the few good things to come from the infamous fuel ban of the late 50's-early 60's was the Top Gas dragsters, especially the twin engined diggers. Names like "Freight Train" are talked about to this day. Ivo's twin Buick was about to debut when the ban was lifted.
![]() ![]() The concept of slower (or at least keeping them at a certain point), safer racing has been at the root of many of the decisions made by the NHRA. When the time ever comes that they want to revamp the rules in a big way, it'll be some combination of many of the things discussed here- there's no one "perfect solution". I favor removing downforce from TF and FC because then the engine output will need to come down in order for it to hook. Once it's found that HP isn't necessarily the solution to running good numbers, the rest of the complexity of the engine will also be moderated- no need for all that fuel pumped through dozens of nozzles, and w/o all the fuel you don't need all the mag output, the blower OD need not be so high (for that matter, older style blowers could be used instead of the butt-ugly blowers now in use as someone mentioned earlier), etc. right down the line. Make an oil-down a points-losing affair, and that'll do it, IMHO. The crowds are gonna want to see a SHOW. If it's not blinding speeds w/teleportation-like ET's, then give 'em smoke! As a kid, watching a pair of dragsters smoke the hides all the way through a 1/4 mile was as exciting as it got. Combine that w/the occasional wheel stand and that was enough. And I believe it can still be enough. |
I raced front engine rails in the fifties.
I think that the reason they all look alike is that they are restricted to certain chassis and the basic design is the same for all of them. Stream lining has never worked because the resistance on a bare chassis is nearly as good as a stream liner and the extra weight actually slows you down. I believe that they have recently shortened the quarter to 1000 feet. |
Are racing rules holding back advances like rules have turned football into practically a 'no-touch' sport?
I think many of the recent rules are safety related, many of these have been knee jerk reactions and not well thought out. Ex the auto shutoff which cuts the mag,fuel and pops the chute. The carbon brakes seem to work pretty well on the fuel cars but are very expensive and maybe not necessary on the Nostalgia cars.
I don't know about the 1000 ft track for TF and FC but it did slow the cars for a while. I think there is just as much carnage now as there ever was just not as many crashes. I don't have real info but that's the way it seems. I think th safety net and barriers could use a lot of work. guard rails are another thing that need work. Just look at the NASCAR stuff that was installed years ago. The sealed motor has been talked about for quite a while I think the tracks don't really want it as it will take away from the pit excitement. Nothing like seeing 15 guys thrash a car from broken to race ready in 45 minutes. Rather than seal the motors why not force a mandatory teardown to the bare bolck between rounds with no replacement parts allowed. This is just for crowd appeal. Mandatory 1/2 track burn out and maybe self powered back to the pits after the run. After all they got rid of the push start and added self starting also added reverser so the fat guys don't have to push the cars back. Maybe bring this back, no reverser, and limit to 4 guys pushing all must be over 250#. haha Or 6 females 4 pushing and 2 pulling a rope limit to 1 sq yard of clothing. haha Maybe forcing the starter to remain on the car. NASCAR has self starting..always has been. It surely would add 100 pounds to the cars. Limit to 48 volts so 4 small high power 12 v batts. Adding much more weight will only work to the car's advantage. More Weight, more traction=faster. |
NHRA Rules
I don't have any viable suggested answers. I DO know that racing was a LOT more fun to watch in the late 60's and early 70's. A T/F car ran in the 6's or low 7's, F/C were a bit slower, but could be recognized as the car they 'were supposed to be. (That's the attraction of the Nostalgia Funnies)
How to slow down the T/F and F/C cars? My simplistic - but likely unworkable suggestion: Smaller tires, and eliminate slipper clutches along with the air timers that control clutch engagement and fuel flow, and, and and,.....(lets get some more evidence of driver skill in here) Lets face it - ( a bit of sarcastic humor here) It was Austin Coil who won those championships. He set it up to make X amount of HP at "this" time, while the clutch was slipping "that amount" and etc. Then he had to point Force the right way down the track. All Force had to do was keep from hitting something and get on it when the green came on. Yes I know - Force can out-pedal anyone and is the supreme driver, (as well as the best showman and spokesman we have seen) but lets put a bit more on HIM and a bit less on his crew chief once they are staged up |
Airplane wing......
Hi,an airplane wing is NOT tear drop shaped,it is curved on the top of the wing,and pretty flat on the bottom. the difference in the shape,is where the wing gets its lift.
Aerodynamics is not quite that simple. There are symetrical airfoils as well as ones that are nearly razor sharp. It's not the easiest thing to create a wing that is efficient at 150 mph and at 300+ without variable camber. ie flaps and slats. Not permitted however.
There is almost an endless variety of already tested airfoils to select from. Here is some reading. Note down a ways how an inverted airfoil can still produce positive lift. http://www.av8n.com/how/htm/airfoils.html |
| Nostalgia Dragster Questions | rednek_racin | Hotrodders' Lounge | 18 | 09-25-2009 11:35 PM |
| Interior Design Questions - Dan, Shannon, Shawn, others? | 72Mark | Interior | 3 | 09-08-2008 05:51 PM |
| Help...rear suspension design questions | FrankR | Suspension - Brakes - Steering | 1 | 06-02-2006 07:50 PM |
| building an oil catch can ? design questions | lowROLLERchevy | Engine | 2 | 03-20-2006 11:13 AM |
| Roll bar design questions | Dubz | General Rodding Tech | 10 | 05-31-2004 03:23 AM |
