Draining Battery - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 04:07 PM
jeffmc's Avatar
jeff mc
Last journal entry: 1941 Dodge Custom
Draining Battery
Hello All
Hey on my 41 dodge with a 302 I can watch the volt meter go from 12 volts to 0 volts as soon as I turn on the key.Don't have to try to start it ,just turn the key on . Also the starter doesn't sound to good ,so could my starter be the voltage problem ?
I have always a problem keeping the battery charged ,if the car sits a couple days the battery goes dead. I think that may be a bad battery , would a bad battery cause the severe voltage drop ??
Thanks
Jeff mc
Old 04-17-2011, 04:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like you have a constant drain somewhere. What all test have you done at this point ?
Cole
Old 04-17-2011, 05:26 PM
poncho62's Avatar
Wiki Edits: 5
If your volt meter is instantly going from 12v to 0, you either have a severe dead short, which would likely cause a fire.........the volt meter is hooked up wrong ......or a bad volt meter.
Since we are not seeing heat and fire, I suspect it is one of the other two.....
As for draining the battery over a few days, yes you likely have a drain on the battery
Old 04-17-2011, 05:33 PM
LATECH's Avatar
I suspect a drain on the battery, but I a also think the battery is shot now.
Put a test light between the negative cable and the negative post. If it glows or lights up, with everything off in the vehicle then you have a drain. Pull fuses one at a time and when the light goes out , you have found the circuit that is causing the trouble.
If no lights go out , unhook the alternator and see if it goes out. You need to unhook the battery (large wire) from the post as well as unplugging the plug.
When you find the affected circuit, you can disconnect things on that circuit one at a time to find wich device is the problem.
Not too many live circuits on a truck that old, at least with the key off.
Brakes, E flashers if equipt, horn , headlights and alternator have power to them with the key off.Cigar lighter to (not that you have one)
I would start with the alternator myself.
msd draining my battery hooey6 Electrical 6 01-03-2009 12:05 AM
draining battery 20ggst Electrical 5 12-19-2004 07:54 AM
battery draining 49olds Electrical 28 12-06-2004 11:59 AM
draining the battery onecoomofo Electrical 17 06-22-2004 07:18 PM
Battery Draining. help please rubberwoman2003 Electrical 15 11-28-2003 03:09 AM
