Drill 1/8 hole in thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 08:46 AM
fat40's Avatar
The other day I had a thread about water temp going up and down, someone said to drill 1/8 inch hole in thermostat, where do you drill the hole in the thermostat ? I have purchased a 160 degree thermostat from Mr Gasket , and looking at it can't tell where the hole is drilled , the Mr Gasket thermostat does not look like your ordinary thermostat .
THANKS FAT40
Old 02-06-2006, 08:56 AM
A stock Mr. Gasket thermostat.
My Speedway thermostat has 3 holes drilled in it, as shown in the pic.
Old 02-06-2006, 08:58 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
it just goes off near the edge so that water can continualy flow and any air bubbles amek it to the radiator, instead of being caught in the block / heads
if theres not enough room to drill a hole, instead just use some tin snips to remove some of one edge
edit: now that you posted pics, just use the tinsnips idea, lol
Old 02-06-2006, 09:15 AM
fat40's Avatar
Drill !/8 inch in thermostat
Hey guys thanks for the fast response and the great pictures , now I know what to do . Thanks
FAT40
Old 02-06-2006, 01:53 PM
johnsongrass1's Avatar
Race it, Don't rice it!
See the hole in the lower picture?
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
Drill thermostat 78 monte Engine 24 04-22-2005 08:12 AM
Thermostat questions flyfisher Engine 5 09-29-2004 01:21 PM
Drilling steam hole in AFR heads 406chevelle Hotrodders' Lounge 9 03-17-2004 08:11 AM
thermostat crshrmn3 Engine 7 10-01-2003 06:27 PM
