Drill bits
Where is a good place to order high quality bits for steel. Im so sick of buying bits from different places that get dull before you get the first hole drilled, or they break off. I have a great drill press, and i always have my speed set slow and use oil. What company can i trust anymore so i dont buy made from china.
www.use-enco.com
Mrwood how's the eye? I really hope you are doing better these days. Last edited by oldred; 10-15-2007 at 12:20 PM. |
I buy good quality industrial grade bits locally from the welding supply store where I buy my welding supplies.
Try Rutland.com
Drill bits
Slow is not always what you want when drilling steel. A 1/8 drill should run 3000 RPM.....That may be some of the problem. Here is a chart to help pick the right speed for the size drill. http://www.ibiblio.org/twa/info/drillSpeedChart.pdf Good luck with those eyes. I have a daughter with a vision problem so I feel for ya. |
drill bits.......
hi,buy only COBALT drill bits,expensive,but last 5 times as long a hss (at least) will drill S/S easily........
any good drill bit will benefit from two items you might like to add to your collection.......... cutting oil is a biggie saves the bits also will make a hacksaw cut like a cleaver. A drill doctor, great tool and works as advertised, however I would suggest the 750 or higher because of the way it positions the bit in the holder.
I've found that I can buy good, better and best drill bits from McMaster-Carr along with a host of other industrial type supplies. The prices even with shipping are competitive with the local stores and without me firing up my Guzzler V10. I ordered some special 2 sided tape yesterday afternoon - and it will be delivered this afternoon by 4:00(I'm at the end of the UPS/FEDEX routes).
http://www.mcmaster.com/nav/enter.as...%3A05%3A46.420 Dave |
| Recent General Rodding Tech posts with photos |
| Left hand drill bits | WakBordr7387 | Hotrodding Basics | 28 | 12-12-2007 01:43 PM |
| stupid question about drill bits | bigfred1958 | Garage - Tools | 19 | 10-22-2007 11:53 AM |
| JUNK HF motor | oldred | Garage - Tools | 34 | 10-18-2007 10:04 PM |
| When to use step drill bits? | scrot | Garage - Tools | 9 | 11-01-2006 06:43 PM |
| High strength drill bit | willys36@aol.com | General Rodding Tech | 46 | 01-27-2005 07:51 AM |
