Aren't they FUN!!
I had about the same problem but after trial and error "figured out" a little trick. Since all drills are not the same as far as spiral, you have to juggle the settings when those two adjusting fingers move in to the cutout/spiral. Holding the drill bit after doing the initial setting and just snugging the collet down, rotate the bit as you look at the non cutting end. Go a degree or two by guess clock wise. What that does is move the drill heel to a negative angle against the sharpening wheel and therefore lower then the cutting edge. I only give the point a thinning cut (split point) if it's 135* and 3/8" or larger - but that's an eyeball cut and usually wont be worth a dam' as it's usually inconsistent, side to side. IMO. And as always, it works for me and am happy with my 'gadget' Dave W |
Don't feel bad, I borrowed a "Drill Doctor" and had the same experience. Maybe I'm just really stupid but the directions were worthless to me also. After a couple of drills I took a deep breath and gave it back to my friend......who couldn't use it either.
Yes leave the bit loose, loose enough to rotate so that the fingers can grab it, position it and draw it to the stop. Then tighten collect. Great tool easy to use, mindless really.
Hope We can Help!
Hey There,
I am the Director of Marketing here at Drill Doctor, we try and monitor discussions about our products, and I became aware of this one. I don't mean to put my nose into your discussion, but think I might be able to help. We have shot a video that discusses negative relief that might help you can view it here: http://www.youtube.com/watch?v=K90WlpZK_MI However, it sounds like the video might not cover the issue you are having. We are here to help! you can contact us through our website, or call tech support at 1-800-418-1439 and we will diagnose the problem. We are just a small family owned business here in Oregon and stand behind our products so please don't hesitate to reach out so we can help. Thanks for letting me barge in. Matthew |
That's fine - if you have a newer version. Unfortunately what Oldred is describing is on an older version which doesn't have the adjustable settings like that - or at least mine doesn't at about the same 10 year old age. Everything beyond the built in setting is a guestimate with the older version
drill doctor.
I had a problem when one of the iron workers tried to use mine. and had the chuck come apart. I was at a show and the rep showed me how to put my old one back together. I have sharpened hundreds of bits with It. When we built a 40 X 120 , 16 ft sides metal building I kept the iron workers in sharp bits and they were very happy. For large drill bits I use an old general sharpener against a 10 inch sanding dist on my combination 6 X 48 belt sander disc combo tool, then manually cut the back relief on the belt sander.
Yes I have the old version and after reading the advice given here today I went back and tried a few things, sure enough there is some improvement but still a lot to be desired. I understand drill point geometry and have been sharpening bits for years freehand by using a good grinder and a point gauge, as I said earlier I still prefer this method for bits over 1/4" but much smaller than that can be hit or miss. In any case I have the darn thing and it would be a neat tool for any bit if I can get it to work properly.
Truth of the matter is I am finding myself needing a magnifier these days to see what I am doing when sharpening any bit , so it would be nice if it can be made to work.
| Recent Garage - Tools posts with photos |
| To drill or not to drill steam hole in 400 | Curtis Thornton | Engine | 9 | 06-27-2008 12:44 AM |
| Doctor J | Doctor J | Introduce Yourself | 3 | 04-30-2006 07:19 AM |
| i am the doctor | omega2 | Off-Topic | 12 | 03-20-2006 10:39 AM |
| To Drill or Not To Drill (Carb Question) | leejoy | Engine | 40 | 03-04-2006 07:41 AM |
| the 11th Doctor? | omega2 | Off-Topic | 2 | 01-31-2006 11:04 AM |
