Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To Drill or Not To Drill (Carb Question)
Old 03-02-2006, 08:31 AM
leejoy leejoy is offline
72NOVA454
ok - so I have to remove the carb to check that right? I already did something like that last summer before the rebuild. I have the secondaries opened a bit to allow more air into the manifold. that allowed me to close down the primaries back to a position where they are using the idle circuits again. now that I am done with the rebuild and having this start all over again, I guess I will start from scratch and adjust the mixture screws also. are you saying it is basically the same result if I drill the primary blades "or" open the secondaries a little more?
