Woodoworking drill presses don't go slow enough
One thing to look for in a drill press is how slow it will go. To get proper surface speed in mild steel 500 - 600 RPM is about right. For a 3/4" drill 200 -250 RPM is needed. Hole saws 50 - 100 RPM. Most cheap drill presses are for woodworkers and have minimum speed of about 500. Getting at least 3 speeds in the 100 to 400 RPM range will really help.
Another thing to check is the play in the quill. Extend the quill all the way down and see if you can shake the chuck. If the quill moves side to side in the housing the drill will chatter in the cut and won't make a clean hole. Hope this helps. |
My grandfather has a Clarke metalworker 8" press, it looks the same as my HF 8" press but his has a lower ratio, goes to like 100 rpm's, mine does 500 minimum. mine, had it a couple years, and it still works good.
check this bad boy out, I've used a little smaller one a few times, talk about a drill press...
http://www.zhongyang-engrg.com/catalog/dq1990-10.htm to be seriouse we have a crafstman floor model, 3/4 inch chuck, i like it, lots of power holding up good. |
I know it's made in China or Japan (well, I know now), but I bought a new Jet floor model and have been very happy with it-absolutely no issues-
drill press
cheap money,cheap quality,if thats what youre looking for,buy MADE IN CHINA...the chinese things today,are where the japanese were 50 years ago. they will probably take 50 years to catch up.
I have bought them through a Snap On dealer before, very reasonably priced and very good quality. |
Some Jet tools are made in China and some are made in Japan and the Jap stuff is usually top-notch just like their cars. The Chinese "tools" (that should be spelled JUNK) are worthless, most anyway. I have a Chinese JET 9" bench lath that is JUNK and I mean JUNK!! but I know of several Jet tools that are real top quality and they are made in Japan. "Made in Japan" these days means quality but sometimes the term is still used to imply junk when in fact the Japs have worked hard to shed that label they earned so many years ago and they now take pride in what they produce, it is also reflected in the price since there are no more "Cheap" Jap goods. |
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
re:Drill press?
If you don't have the paper work or manual that came with your saw, just call a Sears service center, give them the model number and they'll give you the information you need. Any Sears store can give you the number of a service center.
youngster |
| Recent Garage - Tools posts with photos |
| What Size Drill Bit??? | budthespud | General Rodding Tech | 14 | 06-11-2007 02:18 PM |
| drill press questions! | inspiron | Garage - Tools | 3 | 06-02-2007 08:15 PM |
| Bench Drill Press | Theresa Shank | Garage - Tools | 14 | 02-11-2006 05:54 PM |
| Drill press on sale.... should I buy? | speede5 | Garage - Tools | 4 | 06-28-2005 04:15 PM |
| Drill Press runout?? | daimon1054 | Garage - Tools | 2 | 04-20-2005 05:12 PM |
