Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drill press motor wiring
Old 01-28-2012, 10:40 AM
dannronn dannronn is offline
Drill press
I would use Hi speed. In the switch box connect the white wire from the cord to the common wire on the motor. Connect the black wire in cord to one side of the switch and the Hi speed wire from the motor to the other side of the switch. Make sure you connect the green wire in the cord to the frame of the drill press( lug it under a screw) and make sure green is hooked to the ground prong on the plug.
