Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drill press motor wiring
Old 01-29-2012, 05:31 PM
Old Fool's Avatar
Old Fool Old Fool is offline
You could add a spdt toggle switch in the black wire that is coming from the on/off switch..then put the hi speed wire on one side of the toggle switch and the low speed wire on the other side of the toggle switch.
Now you can select hi or low at the flip of a switch !
be sure the toggle switch is motor rated for the amps your drill motor is labelled at
