Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drill press motor wiring
Old 02-07-2012, 11:35 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by dannronn
There is no way to vary the speed on a AC single phase motor, if it slows down to 80% of full load speed the start winding kicks in and will burn the motor up. If you had a DC motor there are lots of ways to vary speed but not torque so it would seem to run out of power at lower speeds. Also if you switch between high and low speed as mentioned in the above post I would use a double pole swwitch. On off on, three position or Hi off low. If you use a double pole 3 position switch (toggle) you can jumper the poles together and double the current carring capacity o the switch. Power to the middle 2 terminals Hi to one outer pair of terminal and low to the other pair.
Totally wrong. There are numerous companies selling variable speed drives for AC motors, and they can allow a AC motor to go down to a creep speed. Old AC drives had issues with surging when the speeds went too low, but newer drives are almost as smooth as a DC drive system.
AC drives for single phase motors vary frequency, not voltage, so they avoid the issues of low voltage that used to burn up motors. By varying frequency rather than voltage the volts stay at 120v., but frequency varies from zero to 60hz.
They're also much cheaper and priced low enough for us hobbyists now.
