-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Drill Press runout?? (http://www.hotrodders.com/forum/drill-press-runout-61590.html)
daimon1054 04-20-2005 07:48 AM
I have a drill press that is about 30 or more years old, it has a tappered arbor for the chuck and I noticed the other day I had a ton of run out (bit wobble), have not used it in a while. Any way I was wondering how to true it up.
Kevin45 04-20-2005 03:17 PM
Does it have runout with a drill in the chuck or the chuck itself? The reason I ask is that some chucks will "look" like they have runout but a drill bit actually will run straight. If the drill bit has runout then you could have dirt in the quill (between the quill and the arbor) causing it to runout or the jaws in the chuck can be bad from too many drill bits being spun in them. Or something could have caught at one time while drilling, flung it around and actually bent something. My guess would be the chuck is just worn out. The chucks can be rebuilt but with so many companies out there it is almost cost prohibitive to buy a rebuild kit anymore. That is if they even have them on the market for your brand of chuck. There are a few rebuild kits out there. Jacobs I know has kits for virtually every one of their chucks. Enco has some reasonable chucks as do some other companies. Travers is another.
Kevin
daimon1054 04-20-2005 05:12 PM
Cool I will check the chuck out, I noticed the tip of the bit moving a lot and did not do a lot of follow up as I really did not know what to look for.
