Drill And Tap SBC Head - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 07:33 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I'm installing an aftermarket serpentine kit and I need to drill and tap a hole in the passenger side head at the top corner. The heads are World S/R cast iron.
The pics show the bolt where it needs to go and shows the heads when new.
Anyone know if it's safe to drill and tap this head? The driver's side appears to be drilled exactly where I need to drill this one.
Any tips would be appreciated.
Name:	DSC01654 (Medium).JPG
ID:	74972   Click image for larger version
Name:	DSC01652 (Medium).JPG
ID:	74973   Click image for larger version
Name:	DSC02983 (Small).JPG
Old 06-17-2013, 08:48 PM
life is a temporary assignment
Do you have two bolt's in it now ?? If so, Can't you just use a nut behind that one bolt ??
Or re-make the bracket to work with the three bolt's you have,,, I would hate to see you mess up a head by drilling it if it's not really needed..
Old 06-17-2013, 09:27 PM
Banned
can be done if need be. But most of the time the hole gets out of round and useless. you need the drill clamped or a drill press to do this right. you can not just drill by hand!!
Old 06-18-2013, 12:16 AM
techinspector1's Avatar
Wiki Edits: 326
Measure the diameter of the hole in the piece that needs to be bolted to the head. Use a drill bit that is closest to that diameter and that will still allow the bit to spin. Position the bracket against the head and spin the bit so that you make a dimple on the head surface. Disassemble the bracket from the head and use the proper size drill bit to cut through the front of the head. It probably won't be very thick material and there will be the water jacket on the other side, so don't drill any further than the first thickness of material. It should be a slam-dunk to tap the hole to the proper size for the bracket retaining bolt.
I seem to remember those bolts as 3/8"-16, so you would want to drill 5/16" to accept the tap. Make sure, I've been known to be wrong. Go easy when tightening the bolt down, remembering that there is not much material there to grab onto before you hit water. Matter of fact, if it's possible to make the whole thing go together with a stud instead of a bolt, I'd install a stud there, anchored in epoxy, instead of the bolt.
Old 06-18-2013, 03:21 AM
Dont stress it too much screw in studs go to water also if ya bust through just pipe dope your bolt!
Old 06-18-2013, 05:06 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks guys. If the worst thing is hitting the water jacket, I got Permatex 2 for the bolt.
I may do as Randy suggests and just bolt together. I was trying to move the compressor and it seems to flex the brackets but no movement at the point where it bolts to the head. May need to tie into a header bolt with extra material welded to the brackets to stiffen it up.
Old 06-18-2013, 08:15 AM
Wiki Edits: 27
a long drill bit
Get a drill bit long enough to drill thru the hole in the tubing of the bracket , then cut up a tin can and wrap it around the bit to act like a drill bushing, use plenty of oil on your "bushing"
Old 06-18-2013, 08:18 AM
To easy to make a bracket..
Old 06-18-2013, 12:34 PM
chevymike's Avatar
I did this and made a jig to get the right location. I marked the drill with tape to tell me have far in to drill. Worked perfect. Just a piece of 3/4" aluminum stock with the drill tap size hole. I notched the one end to clear the block.
EDIT: Opps, thought you were using a factory GM serp. setup. This needs a hole like the late model heads. Are you sure your bracket is suppose to be up that high? I would think it would be like a GM setup.
Old 06-18-2013, 02:40 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks.
Yep, it's that high. Your jig set up is a good idea to run the drill straight.
Old 06-18-2013, 04:42 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks for all the responses.
Bracket fabbing to the first header bolt......1
Drill and tap...........................................0
I'll bolt it all up when it cools to see if it's strong enough.
Mods can move this if they like. It's more like hot rod basics.
Cylinder head fixture for Drill Press zildjian4life218 Garage - Tools 1 11-09-2012 05:14 PM
Nitrous tap & drill size 454headache Hotrodding Basics 3 07-22-2010 06:35 AM
Drill holes in Grade 8 Bolt Head alittle1 Hotrodding Basics 15 02-04-2010 08:28 AM
drill and tap chart TroyBoy Garage - Tools 5 10-11-2006 01:49 PM
Drill and tap follow up Walker Engine 2 07-20-2003 10:24 PM
