Drill thermostat - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-21-2005, 03:48 PM
E.T. divided by $ spent= Speed
Originally Posted by johnsongrass1
Shadow's are notorious for guages that read wrong. And tachs that fail. The pre printed circuit boards are to blame.
Well,sometimes the gauges all peg and half the dash lights go out.So I wack it right on the corner and voala!!! :rolleyes
  #17 (permalink)
Old 04-21-2005, 03:51 PM
Well I changed to a 180 stat from a 195 and drilled smaller 3/16" holes in it.So far I took it out after I filled the system back up and it runs alittle cool prolly 150.Is that OK on an aluminum head??
In a few hours I will take it out after it has cooled completely and see what happens.I've got my fingers crossed.
  #18 (permalink)
Old 04-21-2005, 06:21 PM
Well took it out after it cooled down.Its not heating up then popping down but It took like 6mi befor it came up to were it was gonna run at.And its not running very warm.
My gauge has Cold,then four lines then Hot.It runs between Cold and the first line.Allthough it starts off at about 1/8" befor Cold when ya start it up.
Is it OK to run an aluminum head a little on the cool side??
BTW it is cool today,like 40deg outside.
  #19 (permalink)
Old 04-21-2005, 06:29 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Your better off running an aluminum head on the cool side than the hot side.
the new album out yet?
sup wit da volvo?
  #20 (permalink)
Old 04-21-2005, 08:58 PM
Hey Larry,
I'm having windshield glass cut now and the panhardbar in the rearend straigtened and sleeved and also quarter window hinges machined.
I just started working again about 6wks ago so I'm still catching up befor I can go to town on the car.
  #21 (permalink)
Old 04-21-2005, 09:17 PM
35chev/302gmc's Avatar
gauge fluctuation
I have seen this problem on the 2.5 engine many times before,it is usually caused by a pluged heater core or head gasket problem. I would strart by back flushing the heater core and replacing the stat with one that has not been drilled.
1935 chevy,masters
  #22 (permalink)
Old 04-21-2005, 09:43 PM
The dealer also told me to flush the heater core.Is that what they use as a bypass??
I know one heater hose comes outta that water box were the stat sits.
But it does have good heat though.
  #23 (permalink)
Old 04-22-2005, 12:27 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Could be - heaters make great bypasses and they could very well have used it for that. If they did, your A/C evaporator must use other ductwork or you would be heating your cold air! Sounds like you solved your heat spike problem anyway. You are running @ 180F instead of the 195F so your gauge is responding accordingly. Only problem I could see is if you need to pass smog check, T-stat rating is a pollution control device (modern pollution controlled engines are supposed to run hot), otherwise 180F is fine.
  #24 (permalink)
Old 04-22-2005, 08:07 AM
Yea,we gotta pass a visual.And the check engine light can't be on.But thats it.
Other than that,they plug it in to the puter which tells Albany that another one just got screwed outta $21.
No sniffer or treadmill on 1995 and down.Now 96 and up ya do,but ya get a free tube of KY with every inspection.
  #25 (permalink)
Old 04-22-2005, 08:12 AM
really the only reason to drill 2 holes, NO BIGGER THAN 1/8" in the base of the stat is so you don't get an air poscket when filling the cooling system, it really has no affect from what i've seen on cooling
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
Adjustable Fan Thermostat Working in Reverse JohnTN Electrical 2 04-08-2005 11:43 AM
Electric fan thermostat Novaman78 Engine 4 01-27-2005 01:32 AM
Thermostat questions flyfisher Engine 5 09-29-2004 01:21 PM
thermostat crshrmn3 Engine 7 10-01-2003 06:27 PM
