Drilled/slotted rotors on front only? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 07:05 AM
The mobile view is crap
I'm thinking that it will be fine but figured I would ask first. It seems like I put new rotors on my car and not long after I do I end up with the front vibrating when I brake. And I always use a torque wrench when tightening my wheels. The guy at the parts store offered me a premium rotor at $100.00 per rotor! He said they would last longer, that there is a lot more webbing in them than the standard rotor. I am curious if the drilled and slotted rotors last longer than the standard rotor? And if I can run them on the front only?
Old 11-17-2012, 07:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to suspension- brakes forum
Old 11-17-2012, 09:34 AM
poncho62's Avatar
Wiki Edits: 5
I am sure its fine to put them on the front only if you wish.......I put slotted rotors on my DD 2 years ago and now they have a bit of a vibration...I dont think the last any longer, just my opinion
Old 11-17-2012, 10:11 AM
I have had NAPA slotted and drilled rotors and Bendix ceramic pads on the front of my 1991 S10 Blazer 4x4 for about 2 years and aluminum drum brakes on the rear. I feel the front brakes through my foot and I think the run-out is .008" -.010" . I have not had any braking advantage using slotted and drilled rotors when driving in normal stop and go traffic. The slotted and drilled rotors are designed to vent plasma between the pads and rotors in a high speed stop or during road racing. A street driven vehicle does not need those type rotors.
When I replace the Bendix ceramic pads, I will replace them with Raybestos ceramic pads and Raybestos standard rotors and toss the vented and slotted rotors.
Old 11-18-2012, 08:25 AM
302 Z28's Avatar
Many years ago in my motorcycling days I had a Suzuki GS1000. I drilled the front rotors on the advice of a friend of mine. After laying out the pattern, center punching, drilling, and counter sinking I was through. The operation made the prolonged braking much better, but I cannot tell you if the pads lasted any longer because I sold the bike several years later.
Vince
Old 11-18-2012, 09:29 AM
Raybestos has new rotors that have asymmetrical wavey slots and no holes. (?) Those type rotors must be worth something to some people because the brake parts manufacturers keep making them.
Next time, I will use the Raybestos standard rotors mainly because they are powder coated black in areas where they always rust.
raybestos slotted and drilled rotors Billvill Suspension - Brakes - Steering 5 09-14-2007 08:41 PM
Drilled / Slotted Brake Rotors Advice texastomeh Suspension - Brakes - Steering 9 09-14-2007 06:31 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
cross drilled/slotted rotors chevypunk Suspension - Brakes - Steering 3 08-27-2003 06:45 PM
Where to find drilled granada rotors FAIRLANE DUDE Suspension - Brakes - Steering 0 03-01-2003 08:25 AM
