drilled through water jacket 350 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 08:21 AM
Hey guy's need alittle advise, I have a 350 motor putting together. I was putting on the brackets on the side of block "Driver side" for the motor mounts. There's three bolt holes the bottom one I broke the bolt. First step drill pilot hole, well you could say I went through the broken stud in block. Remeber it's the bottom stud. My plan of action tried easy out no luck the bolt had loc-***. Long story shot re-threaded the hole cleaned out area, filled the new bolt hole with Ultra Grey high torque RTV silicone and then put loc-*** on bolt. I'm suppost to torque the bolt down to 75 ftp, I didn't want to push it so i put 50 ftp, the top two are at 75ftp as my book require's. Will I be safe with this repair? Learned valuble lesson "NOT TO USE OLD BOLTS". Also the reson I only went 50ftp was cause I broke one in the same area but was able to remove. What the ******* lol!
Last edited by 68NovaSS; 04-24-2012 at 08:43 AM. Reason: Profanity. Please see: general board guidelines.
Old 04-24-2012, 08:45 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Depending on how thick the area is, I would have drilled it oversize and tapped it, and used a sealer on it. Going into the water jacket isn't a big deal, you have head bolts doing that.
Read the board guidelines about circumventing the profanity filter, you did that here.
Semper Fi
Old 04-24-2012, 08:56 AM
Sorry for language! But well the measure's I took be efficient
Old 04-24-2012, 09:25 AM
Frisco's Avatar
Glad To Be Here
Putting RTV in the hole will not allow the loctite you put on the bolt threads to work. The loctite will not be needed. Just use the RTV.
NOTE: When using any of the various grades of Loctite, the threads, both internal and external need to be completely clean and oil free for the Loctite to work. Do not use the red (permanent) Loctite on any bolts or studs that will require to be removed often. If you have used any grade of Loctite and are having difficulty removing the components, apply heat. It will soften the Loctite so that it can be removed.
Old 04-24-2012, 09:31 AM
Thanks! So I shouldn't have any water leaks there?
Old 04-24-2012, 09:41 AM
Frisco's Avatar
Glad To Be Here
Clean the threads on the bolt and in the tapped hole first. Apply the RTV to the threads on the bolt. Install and tighten. Allow enough time for the RTV to set up. Shouldn't leak or loosen.
Old 04-24-2012, 09:47 AM
blwn31's Avatar
If you want the best RTV for engine work, get Permatex The Right Stuff.
Keith
Old 04-24-2012, 09:50 AM
75 Ft-lbs?
Those are 3/8 NC bolts and even if upgraded to Grade 8, I wouldnt torque them past 35.
Old 04-24-2012, 09:56 AM
Irelands child's Avatar
Another fix would have been to use a stud instead of a bolt and then using a good liquid Teflon sealer instead of that RTV. This way would 'permanently' have sealed the hole and if you had to remove that bracket, you wouldn't end up draining the cooling system.
Irelands child
Old 04-24-2012, 10:19 AM
Thanks guys! Oh and the rtv silicone was permatex ultra gray high torque
Old 04-24-2012, 04:33 PM
I have a Haynes book for a 73 impala, the actual motor mounts on frame are at 50 ftp and the mounts to block are at 75ftp. was justb tringto follow the book torque spec as i put on new parts. Who knows?
Old 04-25-2012, 10:17 PM
igota66
I'm inclined to agree with Ireland's child use a well sealed stud
as for the the toque setting you quoted "way to much" just tighten it with a ratchet like one of the previous replies said
Crack in Water Jacket?? solidaxel Engine 9 08-27-2008 10:45 AM
Water Jacket Penitrating Studs RexRat Engine 3 09-22-2007 04:28 AM
409 Block with a cracked Water Jacket 62ImpalaSS Engine 1 04-20-2006 12:15 PM
Cracked water jacket ap0001 Engine 7 07-29-2005 03:12 PM
Water Jacket Daved Engine 4 07-23-2003 08:32 PM
