Drilling accy mount holes in passenger side head--SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2009, 09:23 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I recently picked up a serpintine system to put on my 66's current 307.
The head on the drver side has all three holes in the front for accy. mounting, but the head on the passenger side only has the hole for the
sbc long wp alternator mount.
The serpintine bracklet for the passenger uses two mounting spots at the top and the upper front mount on the block.
I have bolted this on with just the one upper and lower bolts, and the inboard upper part of the bracket is veerrrrry close to the head (maybe .015).
How much meat is available to drill and tap in this area of the head???
Looks like this hole will drill right thru a cooling passage (is this a big deal??) just below the front intake manifold bolt.
Anyway--got this serpintine set up --- wp, pulleys, ps pump, fan & clutch, AC pump, Alt, brackets-----for under $150.
This exact same thing in the summit catalog (GM parts) is nearly $800.
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) looks like a car again--painted 12-12-08----YAY
Old 11-26-2009, 09:30 AM
bondo's Avatar
Ayuh,... My 1st guess is,.... Not Enough....
What are the head's Casting #s,..??
Old 11-26-2009, 09:50 AM
Bryan59EC's Avatar
Have no idea what the casting # is. (I am guessing early 70s engine---has corporate blue paint on it---how long was the 307 produced---long wp)
I'm just trying to keep from locating a set of heads that will work on this
engine for just a short time-----till I can sneak a different one past the spouse. (I told her I would run this motor til it quit----so I'm not too interested ripping it apart for any reason---yet)
Even if I drill thru to the cooling jacket----I would think plenty of sealer on the bolt or stud would keep it from leaking.
I just wonder if there is at least 3/8"- 1/2" material for a bolt to grab onto.
Really needs to be a 3/8"-16 bolt-----but perhaps 5/16-18 will clamp the bracket to the head without having to worry about the bolt breaking.
Old 11-26-2009, 02:31 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Drill, tap, insert JB coated stud, wait 1 hour. Bolt stuff up.
Old 11-26-2009, 09:57 PM
holes
Don,t even bother drilling the extra hole. The serpantine belt is a smooth running system so just put a little locktite on the bolts you have and you,ll be fine.
Clint
Old 11-27-2009, 12:53 AM
junior stocker's Avatar
Although it does'nt have "serpentine" style belts, my 82 Chevrolet truck needed an engine in it temporarily while I put together another engine for it. In went a 327 with camel hump heads that I made up some flat metal brackets to bolt the accessories onto the engine. Did'nt drill holes in the heads, and the brackets worked fine. I do have another set of camel hump heads someone drilled holes in the heads to bolt accessories to. Should work fine as long as you have the spacing and alignment correct, especially since as someone has already said, "the serpintine setup runs smoothly".
Old 11-27-2009, 05:04 PM
Bryan59EC's Avatar
This particular bracket supports the AC compressor.
With only one bolt in the head, and another down by the fuel pump, I would be concerned about the AC cycling and breaking the bolt at the head.
Would probably be just fine if I had no intentions of addin AC to to it in the near future.
The brackets are from a mid to late 90s GM pu.
My neighbor had a head in his backyard that I had a look at yesterday--
--appears to have plenty of meat where the hole needs to be drilled.
I think I am gonna tackle it this weekend-----no grille or radiator in the car so it will be easy enough to get to.
Old 11-27-2009, 07:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might consider using a correctly sized stud. That way, the threads in the cylinder head wont be as stressed.
Old 11-27-2009, 09:55 PM
Bryan59EC's Avatar
Will be doing just that.
This particular hole in the bracket uses a stud from the factory and when I got the brackets, I got all the studs and extra braces as well.
Even snooped around some and found that GM uses the same bracket with different bracing on different SUVs-----so I have been getting some of those as well, just to see what will work on the old motor
Old 11-28-2009, 09:39 AM
boatbob2
drilling head.
Hi,i would bolt up the bracket,and the whole system,then drill with the appropriate size bit,thru the bracket,to insure correct placement,but only drill maybe 1/16 to 1/8 inch.remove bracket,finish drilling.if you go into a water jacket,no big thing,use RTV on the bolt threads,or stud as mentioned.
SBC 18 degree head compared to 23 degree head powerwise? sb72elcamino350 Engine 7 03-09-2010 02:01 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
drilling head bolt holes? firechicken383 Engine 1 06-07-2005 08:10 PM
ID Numbers on a 1986 350 SBC Head redcamaro4spd Engine 6 05-26-2003 06:12 AM
