drilling holes in frame for the T-400 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-04-2012, 12:21 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by 0trbo4myCHEVUICK View Post
Im just wondering what the differences are between the denny's conversion yoke( Denny's Driveshaft #SY10-32-CB ) and my bolt in yoke, i know my bolt in yoke has straps for the u joint and is hollow to allow for the bolt and washer. Once i weld that hole shut, what makes it different from a slip yoke? The spline length? Ive got 3 3/4" of spline on this yoke.
Like you said earlier, it has a longer machined out area that rides on the output shaft seal. If you can machine it out cheaper than buying one, go for it.
The Following User Says Thank You to 123pugsy For This Useful Post:
0trbo4myCHEVUICK (08-04-2012)
  #17 (permalink)
Old 08-04-2012, 05:52 PM
prostreet6t9's Avatar
Differential/Driveline
This is a easy fix.. Buy a normal Th-400 yoke and have it counter bored. It will work just fine.
drilling 2 holes in a bracket matt167 Hotrodding Basics 4 11-21-2011 09:50 AM
drilling holes without chipping paint gto_ron Body - Exterior 18 04-23-2010 07:38 AM
Drilling holes for accessory mountings-- can it be done? schnitz Engine 11 07-01-2008 07:27 PM
Drilling some holes in a rear end housing? Javelin69 Transmission - Rearend 7 05-11-2008 08:49 PM
drilling head bolt holes? firechicken383 Engine 1 06-07-2005 08:10 PM
