drilling holes in frame for the T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2012, 02:05 PM
Alright the TH200C is out and the TH400 is in. Time to drill holes for the crossmember. Im curious, do I need to just align the new holes with the old ones only a couple inches back? Or do they need to be slightly lower as well? So glad the search ended for a yoke! Turns out a bolt in yoke with straps was real hard to find. Now the driveshaft mission begins.
Old 07-30-2012, 02:36 PM
BOBCRMAN@aol.com's Avatar
" a bolt in yoke with straps was real hard to find"
Probably one of the most common 400 yokes. Also not really usable, as is, with a rear wheel drive auto.
Yoke has to slide in and out of trans as rear suspension works. Bolt on does not. The hole can be welded up. But the yoke is not really long enuf in the splines to get proper engagement. Be very careful on measurements.
Old 07-31-2012, 09:54 AM
The Corvette style stationary yoke is easy to find, mine is not. Denny's is the only place to get one and they are on back order, they have also been discontinued so theres only a few left. Also, the washer for it has been discontinued and not even the dealer can get it. Ive got the bolt in the mail but still searching for the washer..
I'm adding a slip and spline onto my driveshaft.
Old 07-31-2012, 01:37 PM
What you have is the truck yoke. I've thrown dozens of them away. Really no practical use in automotive. Spline and slip yoke driveshaft is not cool in automotive use. Heavy, hard to balance, subject to wear/slop vibration.
Old 07-31-2012, 11:39 PM
So what, do I need to install a 2 peice driveshaft with a carrier bearing? that sounds like a lot of bull****? The yoke slides almost all the way in but i've heard bad things about using a bolt in as a slip yoke on long bed trucks?
Old 08-01-2012, 03:59 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Bolt ins are used with the 2 piece driveshaft.
Denny's has the slip yoke for using with the one piece shaft.
Old 08-03-2012, 12:44 PM
Alright well suprise surpise, You guys are right.. The slip and spline style driveshaft is only good for about 60 inches. Im needing about 72 inches. I know this topic has been discussed several times over the net, and I dont mean to beat a dead horse. Im just looking for application specific advice because most the threads i see are about installing a truck style TH400 into a car.
My 1982 Chevy c10 long bed has a Buick 3.8l V6 and I just installed the TH400 with threaded output shaft. I already bought the bolt in yoke. I'm looking to get the 1piece shortened, weld a frost plug onto the bolt in yoke, and use it as a slip in.
How much spline engagement do I need?
How much room to allow for slip on the transmission side? I really really do not want to slam this yoke into my Th400.
If the yoke bottoms out at 3", How far do I need to slip it in to measure my drive shaft length?
My shaft sticks out 1/2" from the 4" housing.
The 1350 yoke is 5 1/2" end to end with 3 3/4" of spline and 3/8" of spline missing on the front end. There is also 1 spline missing.
The yoke slides in 2 3/4" then seems to kind of seat into a groove which puts it in almost 3"
when the yoke is bottomed out i can only see about 1/4" of yoke left.
Please let me know if anyone needs more information..
Old 08-03-2012, 01:19 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
You need a yoke from Denny's to use slide in on a TH400 bolt on output shaft.
Or try these guys:
GM driveshaft yokes, transmission yokes
You got to call for pricing.
Old 08-03-2012, 01:47 PM
From what i understand i can just weld a freeze plug to the end of my bolt on yoke and that makes it a slip yoke
Old 08-03-2012, 01:49 PM
the 3/8" of spline missing is a counter bore to allow for use as a slip in yoke right? So it doesent f the o-ring up?
Old 08-03-2012, 02:58 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
You need about 3/4" for sliding. 3/8 missing spline is enough for a bolt tight application only.
Old 08-03-2012, 03:39 PM
ok so slide the yoke all the way in, then back off 3/4", then measure drive shaft length? How much more than 3/8 of spline do i need to machine off?
Old 08-03-2012, 03:58 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Not sure. I haven't looked at a yoke or output shaft lately.
I hope you got a good chuck for your lathe.
Old 08-03-2012, 04:32 PM
Im just wondering what the differences are between the denny's conversion yoke( Denny's Driveshaft #SY10-32-CB ) and my bolt in yoke, i know my bolt in yoke has straps for the u joint and is hollow to allow for the bolt and washer. Once i weld that hole shut, what makes it different from a slip yoke? The spline length? Ive got 3 3/4" of spline on this yoke.
Old 08-03-2012, 08:30 PM
Check my answer to your other post. The push in then pull out 3/4 to an inch is rule for the proper spline yoke combo. Which you haven't got.
If I had to do this job= Find out total rear suspension travel..then, ride height.. When/where the length dimension from the rear end yoke to the trans is shortest/longest.
Use the shortest dimension, pull yoke out 3/8". Thats your length. This will geve you maximum spline/bushing contact and not bottom out yoke internally..
drilling 2 holes in a bracket matt167 Hotrodding Basics 4 11-21-2011 09:50 AM
drilling holes without chipping paint gto_ron Body - Exterior 18 04-23-2010 07:38 AM
Drilling holes for accessory mountings-- can it be done? schnitz Engine 11 07-01-2008 07:27 PM
Drilling some holes in a rear end housing? Javelin69 Transmission - Rearend 7 05-11-2008 08:49 PM
drilling head bolt holes? firechicken383 Engine 1 06-07-2005 08:10 PM
