Drilling oil fill hole in Aluminum Valve Cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2007, 10:14 AM
Hey You Guys,
I bought some cast aluminum valve covers from a Chevy dealer that
have only one hole in each. I got them mainly because they have a good
oil baffle under each hole(PCV & Breather). They have a cast in boss inside
that looks to make for the proper thickness for a grommet if one chose to
make a hole for one. I need an oil fill hole in one cover. I have a push in type plug, with a grommet for a 1.22 in. hole.
I have a 1.250" in hole saw for wood, but don't know if it would work on thick aluminum. Anyone have any suggestions for making a 1.22" or 1.250" hole in the cover without messing up a polished finish?
Thanks in advance for any input!
SS Monty
Old 07-29-2007, 10:49 AM
You can drill another hole for adding oil, but why bother. You can add oil in either hole you have already. Thats the way I do it. Takes a little longer to add oil, but who cares.
Old 07-29-2007, 11:27 AM
Vortech 4.3's Avatar
jack of all trades
i agree.
but if you must drill. either test on another piece of aluminum. hole drilles tend to drill a little larger that they measure at. so be carefull.
Old 07-29-2007, 11:50 AM
Mustangsaly's Avatar
with a oil baffle under each hole thats already there, a separate oil hole is a good idea imo. a good hole saw should make a nice hole without messing up the polished finish, just don't let it walk around. some cheap hole saws might be a different storie I guess. I have a electrician's greenlee hole saw set from 7/8 to 4" (my 7/8 hole saw is for a 1/2 conduit connector). they have put holes in everything from thick plastic boxes to like 16 ga. electrical panels and switch gear to thick red iron structure for steel buildings. a good hole saw a prob a cheap one will do it. or if you have a big enough uni bit / step bit that will do it too.
Old 07-29-2007, 01:15 PM
Jmark's Avatar
My opinion.......Don't drill it!!!
I have the tall Proform covers and use a long trans funnel through the PCV gromment. Works fine even though there is a baffle under it. It takes me no longer this way than through a "regular" fill hole, plus it's one less place for the VC to leak and make a mess!
Plus it's also fun when people notice and say "DUDE!!!!, how do you fill your engine with oil???"
I just tell them I filled it before putting on the covers 2 years ago and hope it's still OK!
Old 07-29-2007, 01:44 PM
techinspector1's Avatar
Wiki Edits: 326
"I just tell them I filled it before putting on the covers 2 years ago and hope it's still OK!"
That'll give 'em something to talk about.
Old 07-29-2007, 06:54 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Use the hole saw and some trans fluid to lubricate it while cutting.Try to do it in a mill or drill press to keep everything inline. I cut 3/8 and 1/2 steel plate in the mill with hole saws.
Old 07-29-2007, 06:58 PM
I never gave it much thought, but i guess I could fill it through the baffles.
I don't think I'll be going to the Jiffy Lube anymore. Might get shot by someone in a jiffy.
Thanks fellas,
ssmonty
Old 07-29-2007, 07:49 PM
jack of all trades
hey, your from corrinth. i used to, and may still do, have family there. haven't seen em in years though . i was there in 1981.
Old 07-30-2007, 06:35 AM
To get a clean cut and avoid scratches from the drills shavings i would put tape on the aluminum around the area of the hole your going to drill. A good painters type masking tape is a good choice they make the tape with different agressiveness for the adhesive so you can remove it without problems.
Old 07-30-2007, 08:04 AM
XNTRCI-T's Avatar
AKA Lee in KC
I fill through the PCV grommet also. My baffles will take as much flow as the funnel allows, which is almost as fast as I can pour it. No worries at all.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
hole in oil pan siuol012 Engine 3 11-04-2005 05:16 AM
Oil Leaks/PCV valve Mrfixmaster Engine 4 06-13-2002 06:21 AM
