Drilling/Tapping Fluid - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-16-2009, 08:39 AM
302 Z28's Avatar
I have used Tap Magic at work, both the ferrous metal formula and the aluminum formula, and IMO it's unbeatable. One function of a cutting fluid is to flush out the cuttings from the hole your tapping or drilling. Some of the more viscous solutions suggested here will not do this.
Vince
  #17 (permalink)
Old 10-16-2009, 09:24 AM
OLNOLAN's Avatar
Tap Magic
Hey Ya'll, Like others here I used to swear by Tap Magic. The original formula contained tri-chlorethane[sic?]. That stuff made beautiful, clean, smooth threads with no surface tearing. The difference in the threads, one with oil, another with Tap Magic, were clearly visable. Seems there was a chemical reaction when used on aluminum, chlorethane + aluminum + heat = fumes? I think this was the problem, but anyway the plant I worked at outlawed it. When the new formula came out, they removed the tri-chlorethane and added a different version for aluminum. I don't think it ever got back into the plant cause you had to buy two different cans. I think Rapid Tap became the replacement because you could use it on any metal. I'm pretty sure the tri-chlorethane was determined to be a cancer risk also, because it has been removed from everything. Well, we used to use it straight for cleaning high voltage cables and equipment. Yep, submerge a rag and your hands right in the bucket, wash your hands in it before going to lunch. Times change, rules change, I guess me and alot of other folks are screwed as far as cancer risk. Back to the drilling/cutting fluid, in my shop I use a sulpher based pipe threading oil for everything. I will take a lot of friction heat. I bought a gallon a long time ago and just refill my little squirt can, gets the job done and a gallon lasts a long time. olnolan
  #18 (permalink)
Old 10-16-2009, 08:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
toploader horrible after fluid change 65fbmustang Transmission - Rearend 4 11-21-2004 08:22 PM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
