Drip Rail repair help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2005, 12:04 PM
Overdrive39
I have a 1939 chevy master deluxe and there is some damage on the passenger side drip rail at the winsheild post. Someone repaired it a long time ago with lead and now I wish to repair it with new steel. I am at a loss because the repair made took away th edetail of the drip rail it looked good at 20 feet but not close up. I am planning on making this car into a street rod so I am thinking of shaving them off or filling them in. Is there anyone out there that has done this before and has had good results. Does anyone have any how to steps on this. I am wide open for suggestions. Thank you!
Old 05-03-2005, 12:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Knowledge base
Do the search thing there as well as perusla of the journals and get soem tips on metal work..
Click here As some of the same guys who are here are there as well with metal working expertise..
Lacking any NOS parts one has a couple of choices on a fix..1) find something that is alomost right and masage it into place..Or build a new piece from scratch to replace the damaged piece..the metal you have may be able to be improved with use of proper tools and technique..
I am sure it can be fixed..just takes a bit of "noodling" to get it done..
OMT
Old 05-04-2005, 02:41 AM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
They're a bit of a pain, but not impossible!
A block of wood, some 1/4" rod to roll the sheetmetal around, a hammer and chisle, mixed with a dash of innovative imagination and a pinch of patience will cook up a mighty fine piece!
If ya need more info, I'll gladly share it.
Randy
Randy Ferguson
Metalshaping & Kustom Paint
www.metalmeet.com
Old 05-04-2005, 04:10 PM
Overdrive39
Thanks Guy's
I am takin' the advice in hand and go bang some metal into submition I was just getting alittle frustrated at the CRAPPY body work someone did. I am sure it has been there a long time because the car has not been on the road since 1973 and I have had it since 1988 it was repaired with lead.............I know I know.......what is takin me so long to.....get er done........That in itself is a long story, that I will not bore you with. I will let you know how it comes out maybe post some pic's. Again Thank you for your help.
S-10 drip rail seal? TurboS10 Interior 7 01-19-2004 08:44 PM
drip rail repair/replacement ghastly53buick Body - Exterior 0 09-27-2003 08:13 PM
1964 pontiac drip rail moldings Mick Body - Exterior 2 11-18-2002 07:18 PM
55 Nomad drip rail repair or replacement nomad55 Body - Exterior 4 09-20-2002 11:07 AM
drip rail replacement charlesjonas Body - Exterior 2 04-10-2002 01:08 PM
