Drip rails - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2013, 07:33 PM
Drip rails
I'm wondering if shaving the drip rails would have any effect on the structural part of the roof? Opinions? Talking about an early 70s Chevelle that will have a 500hp small-block and be used occasionally at the drag strip but mostly street driven.
Old 05-06-2013, 09:23 AM
By effect I meant, will removing drip rails make the body weaker?
Old 05-06-2013, 09:32 AM
poncho62's Avatar
Wiki Edits: 5
Probably not, but its a ton of work. The roof panel is held on at that point. You would have to cut it and weld up the whole seam. More work than its worth in my mind anyways.
Old 05-06-2013, 06:51 PM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
I can tell you that on my 64 Fairlane the drip rail is comprised of the roof pan and 2 other pieces pinch welded together. with the rail cut off flush with the body the roof pan is completely unattached (along the cut).
It is a LOT of work, but worth the effort IMO.
I can post pictures if interested.
Duane
Old 10-02-2013, 09:32 AM
I did that to my 65 Mustang years ago, alot of work but very much worth the effort!!
Old 10-02-2013, 12:18 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
As long as you weld all the panels together, it probably won't make much difference in structural strength. Just leaving the stainless trim off and having it body color would help the gutter blend in too.
Old 10-02-2013, 03:43 PM
ericnova72's Avatar
More for Less Racer
You will also want to do this in short 4-6" sections at a time...cut some off, stitch weld the seam, cut some more, repeat welding, etc. Cut the whole rail off at once and you will have a nightmare keeping everything in place.
drip rails 56GM Body - Exterior 2 07-12-2010 01:41 PM
drip rails CarNutCertified Body - Exterior 4 08-14-2008 09:21 AM
Shaving Drip Rails B-DOGG0918 Body - Exterior 12 09-29-2005 09:26 PM
Drip rails alronz Body - Exterior 8 02-10-2005 11:03 PM
drip rails Jzarczyn Body - Exterior 6 02-05-2004 05:44 PM
