Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drip rair removal ??? for a 62 impala
Old 03-15-2006, 12:04 PM
jvsapp's Avatar
jvsapp jvsapp is offline
just a gearhead in paradise..
Last journal entry: last ones for now.
Originally Posted by poncho62
I have a feeling, that if you gtind off the drip rails, the roof panel will come loose and need to be rewelded on. I think under that seam sealer is where the roof panel joins the sides of the car...........
i agree with poncho... you'll probably wind up having to reweld the seam... might want to take it in sections... like middle then a few inches away... etc... with my friends 68 camaro, running his 468 bigblock doing 12's he had no structrual problems without cage or subframe connectors. i think as long as the weld is good, you shouldn't have any problems...
