Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drip rair removal ??? for a 62 impala
Old 03-15-2006, 09:24 PM
workingclass's Avatar
workingclass workingclass is offline
Tool & Die Repair God!!!
re: Drip rair removal ??? for a 62 impala
Ok, so i'm thinking to take an air body saw or cut-off wheel and in sections remove as close to the actual roof as possible leaving as little material left to grind as possible to help out with heat distortion, than after cleaning up the seam, again in sections weld up the gap or where I can see a joining line. Does this sound about right? Thanks for all the help so far, Kevin
