Drive axle 2002 Mazda Protege - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 02:17 PM
Put a new clutch in Protege and have everything reinstalled except for the passenger side shaft. I can't get it to line up right to slip into the tranny. The carrier bearing is loosened to alow more play. Any help or suggestions would be greatly appreciated.
Old 07-16-2012, 06:26 AM
Last journal entry: Still running strong
I dont understand what their is to line up,im guessing you mean the three c/v bearings that slide into that steel cup.I would install the trans side first then you would have more room to work with the outside end.I havent done this for awile but you have to turn the steernig wheel one way or the other to get the outside end to go into that outside cup.Youll have to forgive me I cant remember what their called.Be sure to fill those steel cups with c/v grease & the boot also.And use the OEM boots becasue there the only ones that will stay on.Ive got an 97 Protege.
HONDA Civic 2002 drive issues Furytom Transmission - Rearend 2 08-05-2008 12:37 PM
Sway Bar endlink/drive axle question schnitz Suspension - Brakes - Steering 0 11-29-2007 09:02 AM
95 protege tail lights mikhitar44 Electrical 4 06-09-2006 05:04 PM
94 Saturn trans-axle reverse drive problem xk8 Transmission - Rearend 1 01-19-2006 06:35 AM
Telling a type of Drive axle Dreadlord Transmission - Rearend 5 09-07-2005 09:13 PM
