Drive belt Diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2007, 12:22 PM
Last journal entry: 69 Mustang
Drive belt Diagram
I'm helping a friend with a Chevy Monte Carlo. Today I noticed that he had his belt running from the power steering pump to the crank and not over the waterpump. Does anyone have a belt routing diagram for a 350 chevy engine. I'm pretty sure the belt should include the water pump.
Old 12-01-2007, 02:14 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If thats the case....I hope he has a electric water pump.
Old 12-01-2007, 03:54 PM
79C10's Avatar
Viva la Migra!!
well , as long as there is a belt on the water pump and it turns it ,and the other belts are aligned with the pulley grooves on your harmonic balancer , it shouldn't matter. I have no power steering on my chebbie and the belt just goes around the alternator and the water pump. I have extra grooves that don't even get used. As long as everything turns round and round , it shouldn't matter which ones are turning together. Just think , if his belt breaks on his power steering , he'll still be pumpin water and coolin down!
Old 12-01-2007, 05:24 PM
The beauty of the Chevy LT1 V8... no belt on the water pump at all. I've always wondered why more engines weren't designed to direct drive the water pump.
Old 12-01-2007, 05:31 PM
No pulley and no belt ... driven internally
Old 12-01-2007, 05:48 PM
justold's Avatar
What year ?? Short or long pump ?
Old 12-07-2007, 08:49 PM
For my '75 GMC with 350 4 barrel, they list two lengths of PS belts. One is long enough to go around onlly the crankshaft and PS pump pulleys, while the other is long enough to include the water pump pulley. There is also another belt that goes around the crankshaft, water pump and alternator.
According to the parts book, since I have AC, I should use the longer belt. With AC I have HD cooling, which includes a seven blade fan with thermal clutch.
The extra belt turning the water pump pulley probably helps keep the fan turning when the thermal clutch engages. The other advantage is that it keeps the water pump turning if I break the alternator belt. I have been running the short PS belt, and managed to break the alternator belt. The engine got hot almost instantly when the water pump stopped turning. The temp gauge moved up so fast that it looked like the second hand on a clock.
Bruce
where can I get an online belt diagram quad 4? F&J Engine 3 07-16-2007 08:02 PM
Gear Drives chevyIIdie4 Engine 32 10-30-2005 02:36 PM
how to remove tach drive from distributor ? dastone Engine 2 08-23-2005 06:10 AM
alternator belt diagram NEEDED! StudebakerBob Engine 2 01-29-2005 11:53 AM
'94 Skylark Serpentine Belt Diagram '77 Regal Engine 0 03-03-2004 07:45 AM
