drive line in 55 chevy bel air - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2013, 09:42 PM
me again getting close to finshing my 327 and turbo 350 trans. my question is if I change the front yoke on the drive line to the right one for the turbo 350 does the drive line need to need to be shortened. ecklers makes a yoke that works with the stock u joint
Old 08-25-2013, 11:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hey Keith, really no way of telling until you slip the yoke in, leaving about 3/4 inch of in/out movement then measure joint to joint. In the link below the measurement "C", with the yoke in position is what you need to know.
Mark Williams Enterprises - Axle Technical Information
BTW I ran a club race today, I need more gear for the long track...
Larry
Semper Fi
Old 08-26-2013, 12:27 PM
Thanks for the info I called elckers about the yoke the sake they didn't think that I would have to shorten the driveline. I ran a 62 rear gear for long and 64 for short. You want the rev limiter to hit about the stat finish line. Just play around within a tooth or two of those numbers
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
Air Ride on a 1953 chevy bel air LowClearanceCustoms Suspension - Brakes - Steering 1 10-16-2008 03:40 PM
55 chevy bel air ginazboyz Suspension - Brakes - Steering 3 11-18-2006 09:11 PM
53 Chevy Bel Air Help! crosswrench Body - Exterior 4 07-06-2005 11:17 AM
'55 Chevy Bel Air - HELP! Blur Hotrodders' Lounge 3 12-23-2002 06:42 AM
