-   -   Drive lines interchangable? (http://www.hotrodders.com/forum/drive-lines-interchangable-216839.html)
chevykid90 03-17-2012 09:12 AM
As far as I understand (and I may be wrong) but the 1st gen F-bodies and the 2nd gen F-bodies have the same exact wheel base, so my question lies with will the drive line from a first gen Camaro/Firebird fit into a second gen Camaro/Firebird considering that they both have a Th350? I have searched everywhere and cant find an answer. I have looked to buy a new one but every place I have looked including Jeg's and Summit have them for 67-69 and 82-(93?) at any rate they totally skip over all second gen years. I have even tried looking up the length of the second gen drive line to compare lengths and I couldn't find it. (I am normally pretty good at finding what I am looking for) I thank you in advance for any help.
SSedan64 03-17-2012 10:51 AM
Should find what you need on this site/forum > http://www.nastyz28.com/
chevykid90 03-17-2012 10:56 AM
Ok, I will check it out. I have read a couple threads on there before but didn't find the information that I wanted. It never specifically said that the drive lines will interchange with each other. If I was home I would be able to go and measure the one that is on my other Firebird and compare it.
