Drive is not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2012, 09:42 PM
I got a 78 K5 Blazer for Christmas. Cool huh, new paint and 76,000 miles. The car sat for 11 years and we knew the tranny stuck a bit. Well it is very hesitant in going into drive and pops out easily. It seems to go in when cold, but once warm, it won't. 1st, 2nd, and reverse are all fine, and shifting is great also. Is there anything I should check? Oh yeah this is a TH350 bolted to a 400 and is a 4x4 with a NP203 transfer case. I do plan on changing the fluid and I hope i don't find chunks just wondering if there is anything I can check or fluid I can dump in.
Thanks,
CHris
Old 12-27-2012, 05:49 PM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
Get the pan off,get the old filter out of the way an look at the valve body your going to see some rust on it, an most likely on some of the spools to.
Old 12-27-2012, 06:53 PM
Ok, then what is the next step? Clean I assume, but how?
Old 12-29-2012, 06:52 AM
78 Z28 Camaro
Look for any rust first,if you find some the rust might have pitted some of the spools an would keep them from moving back an fourth.If you see rust you should take the valve body off an look on the other side for rust on the spools. I bought a junk yard 700r4 an I had to replace 2 spools because of rust pits. Also the bores could have pits in them to,if they do your gona have to get a rebuilt valve body.
Old 12-31-2012, 07:41 PM
78 Z28 Camaro
Theirs alot of seals & some o-rings that sat around for 11 yrs. that won't seal any more. This is the real problem,you have atf that is leaking past seals so their not enough pressure to push pistons an spools.Something more or less like internal bleeding.
Old 01-06-2013, 11:29 PM
Been busy but curiosity got the cat. Took the K5 out and she will go into drive at about 3600 RPM which I do not like. I kept driving her and it got easier, but still not normal. Suggestions, or just keep driving her?
Old 01-07-2013, 02:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you keep engaging the tranny at 3600 rpm, something's gonna give- the u-joints come to mind.
You may have a split O-ring, this happened to me w/a TH250 in a Buick years ago. Took the pan down and a chunk of the O-ring (square cross section) was laying there.
I hesitate to even say this, but you could try some of the canned rebuild that swells the seals. This might get you a few miles before it take a real dump, but if it was me, I'd bite the bullet and rebuild it NOW before that happens.
700R4 Not working in drive hotroddin78 Transmission - Rearend 10 05-08-2011 12:46 PM
90 Chevy Silverado 4/wheel drive not working RAYFIN Transmission - Rearend 7 12-02-2010 10:47 PM
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
Front drive 3.8 Buick to rear drive trans Chopt 48 Engine 0 04-30-2006 02:43 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
