Drive shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2009, 10:53 PM
Drive shaft
How far should the Yoke side into the transmission for proper fit???
I have a 4L60E tranny
Thanks
Old 03-02-2009, 11:27 PM
SSedan64's Avatar
I think there should be about 3/4" clearance left inside the yoke to output shaft for rearend travel. Make check with Denny's
http://www.dennysdriveshaft.com/freq....html#faq_id10
Old 03-03-2009, 07:45 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Originally Posted by SSedan64
Denny's ..... bought an aluminum shaft from them, they are a good shop and the prices are there also.. I see you are in Ga, there is a drive shaft shop here, Drive line service of Atlanta..
They do the same quality of work the price is the same and you do not have the shipping charge to deal with.. I just got a steel shaft built for the truck and it was 150 ..
Old 03-04-2009, 01:19 AM
SSedan64's Avatar
Thanks Pepi, Good Info, there's only one place around here & they don't do very good work.
Old 03-04-2009, 06:44 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Push the yoke in fully. Some 4L60E will have a sleeve with O ring on it tha the yoke slides into for leak prevention. This may give a false sense that the yoke is fully installed. Pulling the transmission tail housing off may be a good idea to look for the sleeve
Yoke should be pulled back about 3/4 inch after it is fully installed.
oil pump drive shaft chevy stupid ? tomthecomic Engine 3 12-06-2008 04:24 PM
drive shaft removal stu_yoakam Transmission - Rearend 13 04-02-2007 03:01 AM
Drive Shaft?? APalusky Transmission - Rearend 15 02-08-2007 07:24 AM
crossmember and drive shaft trouble rbaughman Hotrodding Basics 6 04-06-2005 05:17 PM
St-10/ 2 piece drive shaft question 85406 Transmission - Rearend 1 04-16-2003 02:36 PM
