Drive Shaft
Hi built a street rod and need to know if the center section of the rear end and the transmission are not in line perfect will it cause some damage.There is a slight angle.I know about the pinion angle .Thanks
Bob, you're correct about the offset, however, the pinion is still aligned with the transmission tail shaft laterally. As far as pinion angle, Currie recommends 1 - 2 degrees down angle at ride height, and I believe that's close to the OEM spec.
Some time ago I inquired here if Ford drivetrains are offset in the chassis and got laughed all the way to Toon Town! I'm still convinced some manufacturers do provide a small amount of offset to the passenger side, heck, probably for the heal-n-toe foot brake racers with big feet! -Larry |
